2 Titans Built To Work
i would have to say so the tires n wheels look to be either 12.00R24's or 16.00R25's . . .
Mike
1953 Studebaker M275. Reo 331 I-6, Spicer 5spd-DD, 6.72 Gears, 11.00R20H tires.
1959 Mack B61T. Mack END+T 711 I-6, 2 stick 15spd-OD, 6.38 Gears, 12.00-24J tires.
1962 GMC K4500. GMC 379M-V6, SM420-4spd-DD, 5.13 Gears, 8-19.5G tires.
1969 AMC AMX. AMC 390 Crossram, borgwarner T-10 4spd, 4.44 Gears, G60-14s Front N50-15s Rear.
1975 Mack DM600. 300 Mack 6spd 4.17 gears 445/65R22.5 front n 12.00R20 rear.
1976 Arctic Cat Jag2000. 275cc twin, belt drive, steal grips.
1977 Ford F350. 351M V-8, 4spd-DD, 4.56 Gears, 245/70R19.5G tires.
1988 AMC Jeep MJ. 2.5L I-4, 4spd-DD, 4.10 Gears 215/70R15 front 225/70R15 rear.
1992 Trans AM GTA. 406SBC TBI, 4L60E, 3.73 Gears, 245/50R16 front 295/50R16 Rear.
1995 GMC K2500 6.5-T, 4L80E, 4.10 gears 7.50-16D tires. 4.56 Gears coming soon.
2007 Honda Rubicon 500cc Single, 5spd fluid drive trans, 27x10-12 Front 27x12-12 Rear.
Still in search of M52 5 ton tractor, M123A1C 10 ton tractor
Wow those are some big horses, hope they stack up against the RDs and such. Who knows they might do better than the granites did.
I Don't think this company did a Granite with planetary.
I do remember seeing one of the last serial numbers CL733-3008 with planetary in their color 2-years ago.
Here is their company website;
http://www.dlavoie.com/
Thanks for hearing me out.
Nice,I wounder what the dimensions of the dump body are,it looks kinda wide.
Seen this done many times over the years J&J body company has done a few at 114 inch wide for overseas.
Now Some of you are probably thinking WHY in the world are they using a road truck as an off-road rock truck.
I was told years ago in the coal region not sure of the state Kentucky comes to mind,
Union wages were less if you drive a dump truck then a rock truck.
Today with the (Economic Stimulus Money) I see it in the bid,If you drive a truck you are at $30.00 an hour and $45.00 an hour for equipment(rock truck).
More money in the pocket,But not yours
