Geoff Weeks
Pedigreed Bulldog
  1. If I understand correctly, he is doing at least all six liners. Making or buying a tool would be best. A single liner, I have used a burr and cut two slits almost through, then knocked out a section to curl the liner in on itself. Lots of work but less so than removing the engine and crank from what I was working on. Lot of "clean up" work to make sure no "grit" remains behind. Mild steel deforms easily so has to be thick enough where it hooks the bottom of the liner to retain its diameter. Harder steel can be thinner. Pilot is a must to keep the puller on center. The larger the area in contact with the liner, the less you have to worry about deformation. It is why mild steel slugs work well and why pullers like the one pictured use replaceable hardened lugs, because the contact area is so much less. Many ways to "skin the cat" what works best for you depends on how many you do and how fast you want to get it done. Dry liners tend to be thinner than wet liners giving you less to grip on. Many engine shops prefer to use a boring bar to "bore out" dry liners, as they say there is less chance of damaging the block, like putting a gouge in the bore where the liner sits. They have the advantage of the engine out and the machines at hand to do the job. I have run across a "stuck" liner that sheared on of my puller lugs before. It pulled other liners from the same block without problem, but that "one" required a fresh set of lugs. Never know what you will run into.
  2. Comes down to what you expect in the future and how much you are willing to deal with for short term. No wrong answer.
  3. I've made special tools for the Gardner's, for Leylands for the Kubota. Nothing wrong with home made. Sometimes the time it takes to make one that is as well made as a store bought one, uses time better spent elsewhere. A round "slug" at the bottom sized to fit the liner bore can do a great job... if the crank doesn't get in the way. A "rocker" type that can be passed down through the bore from the top can work with the crank in place. The ones with adjustable legs and two thickness of "feet" to grab thick and thin liners works on multiple engines with one purchase. Crank in or out. I chose one that would work on multiple sized engines, although I used it most on 855 Cummins blocks. After pulling so many liners, the $600 is soon forgot, the ability to pull a liner next to a head that is still on an adjacent cyl has paid off a time or two. I'm not saying you HAVE to purchase, and you can easily copy one if you have the material and shop to make one, but a well designed tool makes the job go so much better. I have plenty of home made tools in the box, for special applications. Do a job once, try and borrow a tool, do it twice buy or build a tool.
  4. JoJo pointed to a place around $600, which is what I paid all those years ago. Yeah, I've pulled dryliners out of one block to put in another. That isn't the point. I forget how many blocks Larry has, and at some point the rationale that "I only have this one" to do, falls apart. Having the right tools not only speeds thing up, they can prevent damage. A liner press over beating the liner in, not only gets it seated without damage to the top, it can alert to problems when it doesn't press in smoothly, that might be missed when hammering away. It can hold the liner in the installed compression to check protrusion. A liner puller over a weld bead, can get the liner out without risk. Yes if you have a lathe, you can make a damn fine liner puller for that bore. A fine thread and a thrust bearing, and you have something every bit as good as that tool above. If all you are going to work on has the same bore, you are set, but you'll have to make another "slug" for each additional bore/block type you work on.
  5. I have the same tool from Apex, had it for years. If you have one liner to pull, on Saturday afternoon, you can try some of the Make Do methods. When you have 6 or more liners to pull, the tool is worth buying. Yeah, if you only are working on one engine with one bore size, you can make your own. Problem with threaded rod, most often it is course thread, which is not what you want to pull with. I feel the same about buying "clam shell, or tapered cone" ring compressors. Yeah you can do an engine without or with a one size fits all, compressor, but when working on an engine like that, the correct tool make the job much easier.
  6. Don't know how thick your liners are in that engine, but a liner puller is worth the money if you are going to do that kind of work.
  7. I didn't know viscous clutches were used that late, my '83 came with one but it was gone when I got it, replaced with a fixed fan, that I replaced with an air clutch. I thought most would have got for on/off or two speed by that time.
  8. A single speed air fan drive, will either be stopped at idle or turning very slowly by the drag in the bearings. A two speed will be turning faster.
  9. There HAS to be air flow over the condenser, so either there is a two speed fan drive, or some other way, to get air flow. It does sound like a typical older system and possibly APADs. I was trying not to mislead so was somewhat vague, but also point you at places to look. A A/C cannot function without air flow over the condenser, period. Without air flow, no heat can move. So either there is some fan operation or there is a HPCO that turns off the compressor, otherwise the pressure will build on the high side until a relief opens or a hose pops. The fact that you say there is no fan when idling, and that the compressor sometimes shuts down and will not re start points to a high pressure problem. I'm leaning toward an APAD's system/ problem. For the high side not to rise while stationary say there HAS to be air flow over the condenser. Switch on the receiver can be either a single (low pressure cut out) or binary (low and high pressure cut out) they look EXACTLY the same and the plug is the same, make sure it is working as it should. I know A/C work, what I don't know is exactly how the system was made on your truck.
  10. Not knowing the Mack system I will make some comments on what you observed. Condenser fans not running: This is a clue, when stationary something has to move air over the condenser. What is the high side doing while the compressor is running and the truck not moving? fans should kick on around 325 psi or so. 2nd some new stuff (and don't know if this applies here) don't use pressure switches but instead use pressure transducers which send a variable pressure signal to the controller. Jumping these can cause problems, but most often they have 3 terminals on them, and IIRC yours have 2. In my experience it is extremely rare for a Tx valve to be a problem. So I see two possibilities. 1: the fans aren't coming on and a safety is locking out the compressor and doesn't reset until the truck is shut off and re started. This would imply some sort of high pressure cut-out in the system, either transducer or a HPCO switch. Again I don't know the Mack system for this year 2: more likely, Control panel, if it is responsible for turning on the fans, and turning off the compressor when the frost switch tells it the temp has reached freezing. Hits both problems if the control panel is where these outputs come from. May be someone else can chime in, does the controller receive the inputs from the frost and binary and then control the fans and compressor (either directly or through relays)?
  11. I've never had luck driving over them even with a steer loaded to 12K. the rubber just flexes, and you don't get the force right at the rim where you need it. Tough one took a duck bill hammer, taking small bites all the way around the rim, and may be a wedge in a few places. Yeah kicked my butt back when I did it, and never looked forward to do it. You need the thicker tire hammer to convert the impact into a wedging force between the rim and the tire bead. A grub hoe just isn't thick enough to move the bead.
  12. Also a true tire hammer would do better than a grub-hoe, thicker in the duck-bill end.
  13. For the tough one, take one of the other rims, wire brush it and put it gutter side up, put the trouble maker gutter side down on top of the cleaned rim, and work the tire off, down to the clean rim and out of the trouble maker rim. then slide off the cleaned rim.
  14. I used a low flow in heavy-haul, and the company I was leased to had many low-flow in heavy service. As I said, it returns some real gains in fuel mileage. Originally, I had a 1500 sq-in radiator and it did ok pulling boilers (high wide and heavy) but there was little "extra" to spare. Both of my trucks I upgraded to fit 1800 sq-in radiators and never had a problem. Coolant filters, SCA's and keeping up on maintenance is important. That holds true if you have a conventional cooling system. My take is the fears are far overblown. If you are going to let cooling system degrade, try and fix with "black pepper and a raw egg", in the cooling system, you are going to have problems. I have met with those that have opted for that method then complain when there are problems, and blame low-flow. Radiator cores cost more, and require more skill to assemble, to get the divided bottom take sealed. Like anything "different" from what people are used to, it can cause people to say it is bad. If you are going to push engines to high Hp, beyond what the factory made, it can be hard to cool, regardless of cooling system type. Fact is: air to air beats all work around's. I will not say low flow beats all, it does not. I also wouldn't pass on a good truck because of it. It went away about 35 years ago, and was only used for about 3-5 years. That makes it odd, but also Cummins was a big player and made a lot of truck engines. 2 stroke Detroit's were on the wain, Series 60 had some teething pains, and Cat would only go to 400 hp with water cooling, if you wanted 425 or 475 you had to have air to air and the limited which trucks could install one in. Cummins offered the 444 that could be fit in any truck. Mack did what they did in their own, but that was limited to Mack brands. If I were building a Big Cam today for a more modern chassie, I would convert to air to air like a N-14 is. I had a Big Cam 1 built in 1979 I had a Big Cam 3 built in 1983 I had a Big Cam 4 built in 1986 or 87 I had a NT88 built in 1988 By the 90's the N-14 was out at least in mechanical versions. The Low flow was only Big Cam 4 and NT88's which is about a 4-5 year run. There are very few people around that had enough experience with them, today or even at the turn of the century. I just happened to be around in the time frame when they were thick on the ground. The L-10 also used the same system (call Optimized Aftercooling ) or OAC in the same timeframe.
  15. I saw a red fox in my yard a week ago, I left it be, as it was hunting rodents. I hear Coyotes often but rarely see them. Very afraid of humans and domesticated dog (which often bring a human with a gun). No mistaking a fox for a coyote, size and shape of the head are give-a-ways.
  16. By comparison, Mack's tip turbine is a more "elegant" solution to the problem, but I suspect more expensive to produce. I could be wrong about that, the last re-core I did on my Low Flow radiator cost me $2100, the out of chassie rebiuld kit cost $1500 for the engine. The need for each went away when space in front of the radiator was provided by the truck Mfg.
  17. Coupla people remarked about this on Freightrain thread, rather than muck it up I thought I would start anew. I had a Lowflow truck in the fleet until retirement and got to know and understand the system well. The 1st thing to understand is there are basically 2 loops in the system that run in parallel. one is the coolant that is in the block and one is the coolant that runs through the after cooler radiator and oil cooler. The all come together at the water pump and mix there. The term "low flow" is kinda misleading. The total flow is the same or higher than a normal system. The term refers to only the amount that is passing through the radiator. The radiator is a two pass core, where coolant enters at the BOTTOM goes up to the top tank and across to the other side and back to the outlet again at the bottom. There is a divider in the bottom tank to keep the sections separate. That divider must be there and seal or the engine will quickly over-heat as coolant will bypass the tubes, and just flow across the bottom tank and back to the engine. As heat moves quicker from a higher temp to a much lower temp, the side where the coolant enters and rises to the top tank is most often smaller then the side where it descends to the bottom tank and out. This allows for much of the heat to be lost when the temp difference is greatest on the "hot side" and then a larger area on the cool side to continue to bring the temp down. An engine at full load only has to loose 10 deg of coolant temp to not over heat. That is why in conventional systems, the shutter thermostat when in the lower tank is the same as the engine thermostat. So when the engine (180 deg) 'stat is full open, (190 deg) the shutters will be full open when the return temp is 180 deg. A conventional cooling system can do this if designed for the load. So a working engine, the return temp of the coolant will be 180 deg. IF you try and use this to cool the air charge from the turbo, it can never get very cool. If, however, you could reduce the returning coolant lower, say 140 deg or 160 deg, you can remove more heat from the air charge. Before low flow or air to air, often 170 deg 'stats were used to try and reduce the returning coolant temp, but this made the engine really too cool for best combustion. These early coolant based systems always took the aftercooler supply from the lowest point in the block to get the coolest water. In the Cummins system, the two loops are in parallel, that means any restriction in one loop, causes more coolant to circulate in the other. There are restrictor plates in the outlet of each head into the upper water rail. The upper water rail goes straight back to the inlet of the water pump, much like a conventional system with a weirstat, where when "closed" the coolant is returned to the water pump. This keeps the coolant flowing at all times and prevents hot spots and promotes better temp control by the thermostat as it has flow over the bulb at all times. Where the low flow system start to get complicated, is the coolant from the block to the radiator and from the radiator back to the block. The "outlet" coolant come from the oil cooler on the side of the block. It then goes to the thermostat housing where there are two thermostats, one that is full open when cool, and closes on temp rise, and one that is full closed when cool and opens on temp rise. The return flow to the block (inlet of water pump) can either be through the bypass thermostat and/or the charge cooler. When block temps are low, the bypass 'stat is fully open and the all the coolant circulates in the block, as temps start to rise, the bypass starts to close . once it reaches about 160 deg the bypass 'stat is fully closed and all returning coolant to the block must go though the aftercooler. Once the coolant from the block/oil cooler reaches 160 the main 'stat starts to open and send some of the coolant to the radiator. The return from the radiator must pass through the aftercooler before going to the waterpump, where it mixes with the hot coolant from the upper water rail, and gets sent back to the bottom of the block. Mixing of the hot upper water rail coolant and the coolant from the radiator via the after cooler reduces the temp of the returning coolant to the block enough so it can keep the engine cool. There are some "trouble points" with the system. 1st any restriction increase on one of the loops diverts more of the coolant to circulate in the other loop. So radiator tubes that a partially plugged reduce the flow in that circuit and more will stay in the block and not be cooled. 2nd the radiator tubes must be smaller (dimpled) to slow the flow through the radiator enough to loose the maximum heat before returning, but still flow enough to provide enough return coolant to lower the block coolant temps (this is where "low-flow term comes from). 3rd, the water pump must be able to move a lot of coolant without aeration. 4th the block pressure in the coolant jacket in a low flow system at 2100 rpm is 46 psi! Chew on that for a moment! The radiator never sees 46 psi because of the restrictions in the system. The 1st Big Cam 4's (low flow) look very much like the Big Cam 3's (high flow) and many didn't see the difference and mixed parts with big problems as the result. The upper water rail gaskets and water pump are different. The water pump looks the same and takes the same housing, but the pulley is smaller and the top of the housing is vented to move any air out of the system. Put a Big Cam 3 water pump on, and it will work, but not cool well and over heat when working hard. The upper water rail O rings have restrictor plates that control how much coolant returns to the inlet of the water pump. Some when seeing this, think it will cool better without the plates or with a bigger hole, when the opposite is true. Opening up the hole allow more hot coolant to return to the inlet of the waterpump and less to make it to the radiator. With the NT88, the upper water rail and water pump (as well as thermostats) changed design to where it is obvious that you can not use the Big Cam 3 and down stuff on the block. To be able to have 46 psi block pressure the water pump belt had to carry a high load and not slip, multi groove belts were used (no change from early big cam) but were less tolerant of being run while loose and would slip at higher rpm/load. Multi rib belts can not suffer slipping long before they shred. Does it all work? Yes! With a large enough radiator and a good, clean system, the charge temp is reduced, the block temp is increased and the fuel mileage is between .5-1 mpg better with the same load. Likely more than you wanted to know about Low flow, much of what I know about cooling came from Glenn Akers, the rest from hard knocks owning a low flow for 30 years and working it hard. None of it is as good as an air to air charge cooler, and when trucks were re-designed for enough room for a charge cooler in front of the radiator, the N-14 got an air to air and the low-flow era ended.
  18. Mine was damaged BEFORE it was boxed. No outside indication of being dropped. No way it could be dropped in a 2 ply heavy cardboard and do this much damage and not leave tell tale signs on the box
  19. Grab the hub at 12-6 and try and rock it in and out. 1st put some kind of jack stand under the axle ! you don't want it falling on you.
  20. Its been a coupla months now. I can't get the correct liners to fit this block, too big around, too tall but listed for this engine. I found a N.O.S. block with liners already installed, 1st arrive cracked, dropped at the factory! Inside a factory sealed box, no damage to the double wall box, but the casting was deformed and cracked. 2nd one arrived in good shape. This is one of those things where you can see the obvious failure, but not the "hidden" failures that lead up to it. The engine failed due to improper assembly, the gasket protruded into the bore, and the piston hit the gasket and shattered. What wasn't obvious until complete tear-down, was he didn't replace the front crank bushing when he installed a -.2mm reground crank, and he didn't remove the timing gear off the crank and forced it though the bushing damaging it. He also "lost" a couple of springs in the gov assemble and tried to shorten the remaining one! So even if could have got the liner in, I would still have had an engine with major problems, low oil pressure and a governor that wouldn't hold the engine speed correctly or might even overspeed. All the "hidden" problems showed when I stripped the original block and started building the replacement. I'll end up with a unit that cost me about what I could have paid for a running unit from a rental house, but I'll have essentially a "new" engine that should outlast me. A cautionary tale about buying un proved things at auction.
  21. The tip turbine and Low Flow cooling were both attempts to better charge cooling without have to re design the front of the truck for enough room for an CAC cooling radiator (Air to air). once trucks were being redesigned anyway, the reasons for the tip turbine and low flow systems went away. Having the charge cooler in front of the radiator give the best cooling, and what has become the std today. At the time, Mack tip turbine was revolutionary, both Cat and Cummins were still using water cooled aftercoolers, and low thermostat temps, to walk the fine line between good block temp and enough cooling for the charge air. After Macks success, Cummins used the low flow system to run the "super cooled" multi-pass radiator coolant through the aftercooler, before sending it the engine. Cat never did and opted for the cooler in front of the radiator, which meant that their engines above 400 hp could not be fitted to many trucks. Cat engines below 400 hp still had the old water cooled aftercooler.
  22. Spicer's sales pitch was "0 to top speed with only 5 stick movements". 14,16, or 20 possible selections.
  23. Where you have to be careful is in the lower gears, that applies to any transmission, it the higher ranges it isn't going to damage something as easily. I would shy away from double overdrives, with the one exception of the RTLO's. 1st there is too much wasted in gearing up and back down, all that goes into heat. 2nd there is the driveshaft issue, have to do the math and make sure you are staying away from critical speed at all and 1/2 true critical at cruise. The RTLO's are really a single overdrive front box with an underdrive splitter, where one stick position down is direct, and top gear is something like .76??? in the front, and when the splitter is in 12th is something like .86. Not a true "double over" where there are two gearsets over driveing the input to a faster output. It is all in how it is plumbed in the trans that makes it seamless, kind of like when the went to the Xbar top cover on the RTO's you can't tell by the shift pattern if it is an RTO or an RT
  24. In my book a 15 is a 12 anyway, and it is a transmission looking for a reason to be. I can see why fleets would spec them as it are a little more "idiot proof" than a 13 or 18. For me if I need the deep bottom end, I would choose 2 spd axles over an 18. 18 has the 15 beat any way you look at it, but in the wrong hands can get expensive quick I have a RTO 14615 in the Marmon, and the only reason it is still there is I retired before I could swap it out. Run what you came with until you have the money and time to change, but when you make the change, make it for the best possible spec's for how you are going to use it, or save your money. Just because it may be slightly better is not reason to jump from one compromise to another. The difference in cost when buying a 10 vs. a 13 or 18 on the used market is going to be a few hundred, but you still have all the costs of the bell, mounts and clutch over what you have now. I would sit tight with what I had and wait until the ideal set-up can be had. Do the Math! crunch all the numbers, startability, top speed, cruising speed RPM, jumps between gears etc.
  25. I think grain trailers can be either full trailer like you posted or pup with convertor dolly. One things for sure, you'll not be backing that out 1/4 mile at speed unless you are a whole lot better than I. I did know someone who could and did back 80' stretch trailer with pipe at 25-30 mph for a long while. Too much to go wrong quickly for me to try it. Same guy also backed a boiler and jeep into a garage in one go, I can do it, but not in one shot.
