Look at oldmacksrus.com under B model info
B75LS
B-75 made from 55-66 no. produced 1,619 in chassis versions T, LT, S, LS, ST, LST
L - light weight or weight reduced by using aluminum components
S - six wheel chassis (tandem axle)
I assume that started with chassis no. 1000 or 1001.
As said above, the Mack Museum can document your truck with copies of the original order no. and build sheets of how it was fitted.
Write or call them
David
hi,
as your number reads, The letter T in the serial number would mean it is a tractor... no T so it was not intended to be a tractor... but anything is possible.. It could have been built as a dump.. but with the light wieght components ( the L in the serial) I dont know how it would stand up to off road service, I have a few 75's and 73's that are light weight and have alum. spring hangers that have snaped off the frame from dump service.
Fred
15 gears...no waiting!
