I've done my share of diff work, I have the torque multiplier for a reason.
I worked one place that had to re-torque the rotex bearing on equipment yearly. They had either a 1" or 3/4" torque wrench ( 40 some odd years ago, I don't remember which it was)  and there was barely room to swing it in the service bay with the machine in there.
Torque multiplier is dead easy: put on the nut/bolt to be tightened and install a short reaction bar to someplace solid on what you are working on, dial the 1/2" torque wrench to the correct input torque and start ratcheting away until the torque wrench clicks. In most cases a one man job.
works great on trucks, there is always the frame to act against.
And I want you to succeed, which is why I am passing on hard learned experience.
There is tools made to slide the hub, wheels and tires off as a unit. I know one shop that does all brake jobs that way inboard or outboard. He claims it is much faster.
I kinda figured that truck wasn't your sole means of employment, but you never said, and I didn't assume.
There was a shop I used in the valley (if we are talking the SLC valley) that had no problem working on old stuff when I was out there. No idea if they are still in business. I'll see if I can find their name and number. I know they did a pinion seal that was on my '83 was gushing, and I wasn't going to drive it home over 1000 miles like that.
United Diesel Service 1905 pioneer. Did fair work, I used them a coupla times, but that was a decade ago so things might have changed.
They were one of the many I contacted about the engine work. Talked with about a dozen shops big and small. They said they would get back to me as far as sourcing parts etc. All me if they could find parts they were 6 to 8 weeks out.  Never did get a call back from anybody I talked with.  All shops I talked with even on the brake job as at least 4 weeks out.  If it's a job I can do I'm not waiting that long for something I can do in a day. I have no problem getting my hands greasy.  I just get the impression from the shops I talk to they have no interest in working on a 40+ yr old truck.  As far as the brake job I did pick up a dollie from Harbor freight and modified to to support the hub with the inner wheel still on and once I had it so that it would slide on and off straight the job was basically a piece of cake.  The only delay was I had to have the shoes relined being new shoes weren't available locally, but that only took a day. Not too many parts for my truck are available locally and unless it is just a generic parts that doesn't require a VIN number to look up, I have to go to the dealer because everybody tells me that my VIN number isn't a good number.  My older parts guy, been with Mack for 30+ yrs, there has no problem.  The newer guys need to be shown how to look up my VIN.
I do appreciate all you are passing on to me and I'm not too proud to not accept criticism and or suggestions/insight
Just trying to help.
In my case, I had the part numbers in hand when I called them for my Rockwell QAR rear pinion seal. Still not a slip in by 10 am and pick up the same day deal. I layed over in a motel and they came and got me.
I am all for doing it myself and most times I do, but somethings can't wait or at least shouldn't if you are talking a trip of over 1000 miles. Yes, I have come across "mechanic's " that do more harm than good. These guys did what I asked, and while not as quickly as I would like, the workmanship was acceptable.
Good shops are often booked out several weeks and give preference to their local customer base, and bad shops, well why would go there. I can't remember who recommended United, it might have been the truck equipment shop that built the DOT plow trucks (whose name escapes my memory right now).
Edit: The truck builder is now call "Reading Truck" 4400 and Calif. changed its name or sold, That is why nothing "rang a bell" when I went looking for the name.
Edited by Geoff Weeks
I totally understand that and I understand a shop not wanting a truck to take up space trying to source parts. It just would of been nice for someone to at least communicate with me rather than say they will try and then I never hear anything from them.  I understand that lack of communication was from shop management and not the mechanics themselves. When my engine was down I lost about a month waiting to hear from any one of the shops. I was just intimidated by the size of the job I was looking at and unsure about what I was looking at.  Once I got into it it was all pretty much straight forward and didn't have any problems, except time, in sourcing parts. The machine shop I had do my head work also had no problems sourcing what he needed. I was luck on the head being it wasn't cracked.  That one I wasn't able to locate, but once the machine shop informed me the head was magi fluxed (not sure on spelling) wasn't cracked and was rebuildable I stopped looking. I did find a couple of heads but they weren't maxidyne heads and from what I could find wouldn't work.
