Ok, was grinding on my flywheel and after getting the surface flattened I measured height and it is almost .200 deeper then stock spec of 2.797.  We didn't take but .050 off so apparently someone ground it way down and didn't take the upper surface down.  I bet this clutch slipped like hell from the last rebuild.
The book says don't take more then .070.  Well it will be .200 down.  I know it won't make any difference in my set up and can't see it having any issues with function.
Anybody have thoughts?
https://www.bigmacktrucks.com/topic/76279-flywheel-question/
