1999 Navistar Grumman/Olson van no-start
I realize this is not a Mack but you guys are good so here I go….
Crank/no-start . Obviously some electrical issues at fuse panel on driver side.
power box with fuses under hood test ok
I believe I have fuel pump issue as well but want to check all electrical first.                    I  have no fuse or electrical diagrams.
can anyone help?
thanks
If the fuel bowl heater shorts out, it blows the power supply fuse for the pcm.
On ford pickup easy way to check is if the cigarette lighter don't have power cause that is on the same fuse too.
T444 is what is was called in International products and 7.3 Powerstroke is what it was called in Ford products, Same engine as far as I know. International is known for crapy wiring so that's something that should be taken care of first before the HEUI fuel system. I'm not an expert HEUI systems but Adapt Ape on YouTube has some guides on troubleshooting them. Good luck
If it cranks and won't fire ! There's some parts canon ammo  that isn't to expensive!  replace the crank sensor! this on these have been known to fail ! won't throw any codes! Experience Based comment!
Just sayin!
Thanks…. I have now realized that there IS a self-diagnostic test I can perform on this.
I will be checking this afternoon to see if any faults are stored.  I have noted that a bad crank sensor won’t throw a fault…
Sledog
9 hours ago, tjc transport said:
If I remember correctly, a bad cps will not show tach when cranking.
Some models newer 2000 new don’t do the tack thing not varied me me though!
rumor
Injection control pressure regulator magnet can fall off only a stamped tin nut holding it on its down in the valley in the high pressure oil pump
If your going to be a bear be a grizzly
Got it running today….
Bad connections at a few key fuses at fuse block in cab.
Starts well but no throttle control . will be checking that next..
sledog
