8v92 oil psi
joes mack
what should the oil psi be on a 8v92 fresh oil and filter change about 20 hours ago when the truck is cold it shows about 60 psi at idle when it warms up it shows about 10 psi at idle when driving it shows about 80 cold  and 35-40 when its at operating temp. when i let off the throttle to stop the low oil psi alarm goes off for a second and oil psi is about 5 psi.
