antifreeze in oil
85 mack
Just drained the engine oil on my Mack e6 350 motor. There was some antifreeze in it, not much. The  truck is a 1985 RS688LS . It has 105000 miles on it and 4600 hrs.  Any ideas on where it might be coming from and if so how hard is the fix?
Pull valve cover and check core plugs , prone to leak with age ,  they are the 1/2 square plugs under valve cover . If they are. The issue it will be visible , just drain coolant down some remove and clean install pipe thread compound and reinstall , or could be one of many other issues . Start with easy stuff first
