Power loss / Engine brake loss
Gord Josephson
I have a glitch with my truck where I lose power and engine brake function. I have had the truck at two separate dealers and they cannot identify the problem. One possible reason could be something in the wiring harness.
My electrical fault light will also be on on the dash while this is occurring.
It clears itself up while driving sometimes and other times it will clear itself up by turning ignition on and off.
Any suggestions?
Edited by Gord Josephson
  • 3 weeks later...
I may have same issue. 05 E7 427 with 549k miles. Engine brake activates as normal but will not deactivate with switch, go pedal, or clutch. Pull over let engine idle with Jake switch off, all returns to normal. Have also had unexplained loss of power twice. Resembles loss of turbo. Pull over, idle good to go. ????
