E-7 timing selinoid
I was told there is a screen somewhere in the oil supply going to the timing selinoid anyone able to point in the direction of it.   We're still having intermittent smoke and rough running Mack scanned it and says timing selinoid is what it says.   The blink code is still 6-3.  We did replace the timing selinoid and it's no different. Someone told us the 6-3 is actually engine brake output witch makes no sense to me.  Any help be appreciated
It may be the econovance its self the spring may be broken or simply worn out! If working properly  When the engine starts it should stumble and sputter and smoke  till the oil preasure comes up then smooth out if its not doing this and u have changed the sol  it could be a physical issue with the advance its self!
