what are GBA numbers?
If the truck's components (engine, ect.) are all original, then all you should need to provide the dealer is the model and serial number off the vehicle identification plate on the driver's door.
Are they asking for a GBA number stamped onto engine parts?
49 minutes ago, Elitedownunder said:
Im am buying a in chassis rebuild kit and they want the GBA, and I have asked the question where I get this GBA from...is GBA a MACK casting number?
Okay, they want the 11GBA number that is stamped on your engine's identification plate.
But if your engine is original to the truck, they can simply use your model and serial number, off the vehicle identification plate on the driver's door, to obtain that 11GBA number and research your engine parts requirement.
Is your engine original?
How old is the truck?
