Puget Sound 'Western' R's
Those mid mounted lift axles are pretty common in Washington, Orgeon, etc.- They can run at 105,500 pounds weight instead of the usual 50 state limit of 80,000 there. But they still have to meet a "bridge formula", which usually requires 8 axles and they have to be spaced far apart, thus the extra axle mounted so far forward of the drive axles. This would typically be coupled to a 4 axle trailer to get near the maximum weight allowed.
The same weight in Washington can be done on 7 axles, Oregon is 2k Less an axle ergo 8 axles. Was told 12 steer, 12 lift, 34 tandem, 34 trailer and think it was 12 per axle or somewhere in that ball park to 105500
