Whats in the box on the right side of the truck behind the front wheel on an R700? the left side is batteries, ehats in the right side?
Grant
Hi Grant, most R model Mack trucks had batteries on both sides of the trucks. A total of four usually.
bummer, then i need adother battery box. thankyou.
Grant
hey grant ,my truck r685rst only has i battery box on the l/h side behind front wheel my truck is only a 12 volt system with 1 battery to run electrical system and air for the starter motor.maybe rob has electric starter motor or 24 volt system????cheers adrian
Hi there, never been around an R model that had air start so I'm certainly no authority there. Only two of my R models are 12 volt start. The other is 12 volt electrics, but 24 volt starter like B models. All of the trucks have battery boxes on both sides and use four batteries in total.
Grant
Hi Grant, 95% of Aussie Macks wereair start up until about mid 90's, so they only had 1 battery box, it was mounted on the lhs, air start tanks were mouted on the rhs.I think when S/liners & C/liners came out they might have had extra batteries even if they were air start. Jeffro
Hello, no worries. thankyou, thought it was batteries, but the one i caught a quick look at the other day looked like it was to small, not enough depth for batteries. the one i am wrecking now had batteries on left side only and was electric start.
Grant
Grant
Hey Grant those V8 V/liners had really small battery boxes on each side behind the wheels. even when they had airstart. jeffro
i see. ah well, more bits to get then. i still have to get an R700 western hood yet and an 18speed RR then i should have enuf parts to build it.
Grant
