B-61 Door Alignment
My question is about the bottoms of the B model doors sticking out past the body line. The doors were originally the same way before they came off. I can get anymore alignment out of the hinges. The hinges are correct and were re-bushed. Did some come from the factory like this? Is that how they are supposed be? the stick out about an 1/8" all along the bottom of the door passed the rocker panels.
Thanks,
220cummins
Edited by 220cummins
Thanks,
220cummins
This fitment is common without modifying either the door shell, or the hinges, or both. There is no detriment that I see as the door skin/shell does compress the perimeter gasket for a seal to weather.
All of my trucks are as you mention.
thanks a lot thats how my parts truck was as well and how my dad said the b models all were(he used to redo dm's, brockways, and some b models every year for the concrete co he worked for). i just wanted to make sure.
thanks,
220cummins
thanks,
220cummins
Guys, speaking of door seals, what is a good replacement product for the seals?
  • 2 months later...
