E9 starter
I haven't but mine is still 24 volt, I have pondered swapping to a high torqe 12volt.
I haven't done it yet but my local starter shop said to use a 12v 50mt Delco for mine.
All the E9s I've had we're already 12volt . My MH had been switched to 12 before I got it. Only reason I knew it had been 24 previously is because they left the series parallel switch on the shifter stand with all the wires cut off. I put a new starter on it when I rebuilt the engine only because it was one of the only things I hadn't replaced and it was already off to take the oil pan off. If it's wired for a 24 volt system I'd just leave it. But if you change it to a 12 volt it's simpler and will start an E9 with ease too.
