Steering wheel removal
I posted the other day about swapping a white 20" wheel out of an old F model on to my RD model. I'm just curious, what's the best way to go about pulling the wheels off? Once I get the horn button and the nut off, is there a certain kind of puller that works best?
Jake
I used a standard steering wheel puller.. Has 2 or 3 jack screws...i would spray the splines with some PB blaster A day before to aid in pulling it... Some are stuck on tight...others slip right off... If you ever plan to remove it again use some anti seize on the splines when you install it..
