Order in which heads should be torqued
r686st
I have a '91 RD690S as some of you may know and I'm putting new heads on it. I couldn't find out from Mack but I thought yall might know the sequence in which you torque the heads on the motor. It has a newer '96 EM7-300.
The book I have says final torque
5/8 head bolt studs and nuts 175 ft lbs
5/8 head bolt cap screws is 220 ft lbs
9/16 head bolt 150 ft lbs
3/4 head bolt 175 ft lbs
V-8 head bolts 11/16 235 ft lbs
Valve Clearances 673,707,711,675,676 Cold Static adjustment
Intake .016 Exhaust .024
865,866 intake .016 exhaust .026
cyl head.pdf
Robert
