Power divider or Rearend?
OK so we took off the side plate off the front rear end and their was a chunk of teeth lying there. it was from the gear that connects to the power divider so we bring the power divider to Ballard Mack and they order the parts. Well they call up today and say the parts don't match. The ones they ordered are 30 something teeth on the inside where as the one in it has only 8 teeth. they ordered the parts before taking it apart. Are the 8 tooth after Market or for a heavier duty carrier? :idunno: the truck came from Mass so idk if they put heavier carriers in since Mass lets you move anything with them. anybody have any info?
Matt
Sounds like you broke a tooth off the pinion gear. The ring and pinion are a match set, I'm confused on what they ordered. If you broke the pinion you should need a ring and pinion. Its possible that someone changed the ratios so they wont match the build spec. The ratio should be stamped on the right front flat area on the rears.
