Polarizing generator from + ground to negative ground '59 B61
Hello Guys,
did a search and found that to change over to the negative ground setup and have the original generator work I need to polarize it. What terminal do I need to hook the + side to? Also do I need to change how the wires are hooked up between the gen and regulator, or does that stay the same?
Thanks,
Jason
-Jason-
1959 Mack B61T single axle short wheel base, concave cab. 673 diesel, duplex trans. Running but under contruction!
Hello Guys,
Thanks,
Jason
You need a different regulator for negative ground. You cannot feasibly change the polarization of this unit. Once a new regulator is fitted, touch a wire from the positive terminal of the battery to the terminal on the generator for just a second to "polarize" it. Start the engine and it should be charging for you.
Now would be a good time to fit an alternator rather than retain the original generator. A Delco "10SI" is very easy to make mounts for and fit to the engine. It is also self contained with a regulator.
Sounds like its going to be a alternator. I talked to the Generator shop that built me the starter, they recomended a 22SI as its a truck alternator and puts out 100+ amps. I think I'm gonna go that way, its only $125 anyways.
Thanks for the imput guys.
Jason
-Jason-
Jason
The 22SI is a good alternator and is more "rugged" than the 10SI series. Glad to hear you will spring for the extra dollars for the better product as most will not. A 10SI can be had for less than $50.00, but the vibration of the diesel can make them short lived being full of chinese components.......
