Brockway 761 & others
bullhusk
Is the work on the nose below the headlights part of the modification for the V12?. That truck stands out from any Brockway or Pete I have seen with a V12.
Good question? I don't know? Maybe Rob would know, the back part of the hood is stright across so that there is no hole where the cab vent would be, the ext. spacer between the cab and hood has the cut out. Stephen Lucrino from the Brockway Site did the Motor work for me and checked the internals, looks like all has been redone. It runs good and does not smoke
FW
post-5662-0-90764100-1327365310_thumb.jp
New truck looks good Ernie! i still think the blue one would look good down here! how are you gonna paint the R-model? something like it is now? i like everything about it except the dual headlights,just not used to seeing them, looks odd to me. Got much snow up there this year? i havent been through jersey in a while..............................Mark
I'm thinkin the same colors as the F-Liner, but using the same lines (smoke stack lighting) still a good deal of work to be done
Ernie
