Need help super heroes
cgallamore
Vgt positioning sensor
Voltage low or shorted to battery
Occurrence count 15 In 8 miles
Service required--eng pwr may be reduced
All gauges normal exept boost, hard pull runs it up to 37 psi then dumps back to 10 or 15 psi
Fault will occur pulling, flat, or down hill
Western ok. Rolling hills
Hope Mackpro didn't have to many bud lights last nite
He's Gona get a text about 9:30
No BL's last night, I was up at 6 on my way to work, Got your text this morning. I was at my other job, I work 7 days a week in the winter so I can have more play time in the summer!. I would say just replace the turbo actuator/VGT when you get that many codes on it. Unless you have a wiring/harness issue or oil/coolant in the harness/ engine ECM or an air pressure issue to the . VGT or to the VGT controller box. With the local guys, I usually clear the codes and recalibrate the turbo and let them run a day and see what happens, but usually we end up replacin the actuator. Thoses things are $$$$$ about $1100 I think. And some times their like your starter "dont want to come off".
Boost is all over the scale
It would be doing fine never more than a mile
Then throw code and derate to less than 20 psi. And exhaust temp go out of site
After a minute or 5 the code will go inactive
If I stayed on it boost would jump to near 40 psi
If I watched and stayed out of the throttle enough to keep boost around 30 it would go a little till derate
This place is crazy big mite get to it tonite or tomaro
I would love to work on your truck as I have had 2 weeks of MP's falling apart, bolts stripping out , bolts breaking off in turbos and other failures due to poor parts quality. Someone give me a grey motor to work on quick!
Someone needs to help Bigen with his truck - not only is he stranded, but so is my Mack that he is going to haul home for me.
Time seems to drrraaagggg when you are waiting for wrenching to start!
Their pretty sure it's an actuator
Would you like us to put one on for you sir
Ok as soon as we can get it back inside we will get right on it, hopefully by this after noon
Don't you just love what is called good service in a big corporate setting
