Oil Bath Air Cleaner
Guess I got sloppy about maintainance. When I dropped the pan on my oil bath air cleaner the oil was carmel colored, and there was water under the oil. It was last serviced 6 months and 600 miles ago. how often should I check it. I wonder where the heck the water comes from- not much rain in AZ-
thanks for the info. You never have water? hmmm. I will say that the shop did not put any gasket on it. When I replaced the oil I added a 1/4 inch rubber rope around the circumference of the junction, under the clamp. I'll be watching it more closely now. thanks again
On my 64 B-61 I get water in mine ever so often during the winter. I think it is the snow getting sucked in during operation. I installed a new rubber seal as mine was deteriorated several years back after first acquiring the truck because the pan was nearly 50% water.
When I first got mine, after 20+ yrs of sitting outside at towing place I changed the oil in the filter and it had no water in it. Heck, is there even a gasket? I don't recall one? CRS!! The pan slips inside the bottom of filter so I can't see water getting in from there.
Strange......
If water in the oil pan is not common, I might have anotther problem somewhere that is allowing it to get in. One time a dealer serviced it and slatherd silicon under the circumfirential clamp, the next shop put a rubber rope gasket, and last shop put nothing. Water has gotten in before, when I lived in rainy Seattle, but i don't get much driving rain in AZ. think I'll dig out a manual and see what is recommended, should have started there. thanks for the opinions
