Air Regulatior
joes mack
will a bad air reg let air feed back through? the truck always built air fast but now it leaks off over nite and slowly builds up and goes to 130/150 psi. normaly wouldnt be a prob but its on a fire truck and every sec counts. the truck just started doing this and i believe the high air pres caused the low air switch to start leaking. i changed the switch today... thanks in advance joe
I dont know what your saying about bleeding back. It ahould not let air bleed anywere but to the unloader valves. It they were leaking by then the air pressure would leak down to maybe 90 psi if the engine was not running.But after that the air is shut off to the unloader. But if this was going on then it could let the pressure to build up higher because the unloader was not unloading. Need more info. In my part of the country only certified mechanics can work on fire trucks. I worked for the dealer many years and never was allowed to work fire trucks. They said first thing i was not slow enough to make it a profitable deal to certifie me.I think i remenber saying thank God.I did work on some ambulances but that was only when they was hard up for help.I also could not work school busses.I could go over and help one of the trainess that was certified.
the air will bleed off to 0 on the primary and secondary air systems over nite. but i cant find a leak any where. then it started building really slow and high air pres all at the same time. this has me wondering about the regulatior.. joe
thanks i will check the gov i was calling it a regulatior for some unknown reason (i must of had a brain fart) the trans is a 5 speed without any air to it i think its a spicer. ill look and see if i can find the check valves and check them for sealing.. joe
Hi, the gove sounds like the best place to start. that would more than likely be your high pressure problem, wheres the safety valve? if thats been blowing off lately due to air it may be leaking? mines in the wet tank, but yours may be differant. you may need to get a bit of garden hose and stick it in your ear and go through all lines and conections to try find the leak.
Grant
