Vent Window Latch
you are looking for something that is really hard to find and is bad on most of the B's I have seen. That is why they go crazy on ebay when one comes up....I don't know of a good substitute and yes, the rubber is available thru Barry at Watt's but that is even crazy $$$$... around $200 for just the rubber if my memory is correct. wish I had better
Back when the B's were still in service most of them were missing the vent widow latches. They would get really hard to turn and then snap off. Good luck and if you do find a set keep them well oiled.
  • 3 months later...
I have a missing lf vent window latch and the right side doesn't work too good on one of my B models. Anyone know of availibility or a good substitute?
Thanks Chuck
Hi Chuck, If you are still after these, I will have a look at what is in my heap of goodies. I may have a very used pair. Do you need just the handle part or the part that goes under the window as well?
Regards. Rod.
Proud owner of;
1961 Mack B61 prime mover.
1981 International ACCO 1810C DualCab Fire Truck
Regards. Rod.
Rod, I think I have found enough for my needs. Thanks for the reply though.
Chuck
