Geoff Weeks
Pedigreed Bulldog-
Days Won
7
Content Type
Profiles
Forums
Gallery
Events
Blogs
BMT Wiki
Collections
Store
Tried heat, rubber wheel (that was made for removing decals) and someone suggested oven cleaner (don't do it, takes the paint off). no luck, head a a plastic scrapper only "flakes" the decal. I have done others with heat and rubber wheel followed by rubbing solvent to remove the gum, but these are not budging
Anybody got a recommendation on the best way to remove old baked on decals that have been on the truck for more than a decade? I've got to get the old ones off the Marmon, and get it sold. Started right up, I don't remember when the last time it ran, but has been years not months. Didn't take a full air tank before it was purring.
E7 safe operating water temperature
Geoff Weeks replied to coop661's topic in Engine and Transmission
A lot depends on the construction of the engine. Those with water cooled aftercoolers, it is always a trade off between best temperature for efficient running and still be able to cool the intake air from the turbo. Those without an aftercooler or with an air to air, the limiting factor is how close to boiling it can run without cavitation damage to the liners. Those that can handle higher radiator pressures the higher temp they can handle. When the coolant pressure is held to around 4 psi than 218 to 220 would be the high limit. There is no hard and fast rule as to how hot is too hot. Look at the owners manual and see what they recommend. Deutz (air cooled) are known to run fine at 300 degrees F head temp just fine. -
Loose like the caps drop in, or loose like the yoke has spread? Long and short of it is driveline is not a place to cheap out. 1st I would try with a new joint to see how the fit is before condemning a yoke that may not be able to be replaced. You could take the all the dimensions and see if there is another yoke that could be machined to accept a speedo drive gear, any speedo drive gear then adapt the ratio to the head with a ratio box. But in reality what ever you do isn't going to be cheap. It is going to come down to what you can find.
IIRC on the east side of US 20, never stopped there, but I do remember it.
Forgot to mention the box with all the different gears to make up ratio adaptors. This application was the 1st I've seen where they said the gear and yoke were supplied as one. New one on me as well.
I can strongly recommend going with an electronic speedometer. Makes life easy. Cost isn't much and the yoke for electronic seams to be available. If you must keep the mechanical and are willing to spend the cash to keep the original speedometer, Dakota digital makes a steppermotor cable drive to convert electronic pulse to speedo cable drive. Cost plenty though. depends on what your situation is. For a working truck, I would go electronic and be done with it. Hobby or restoration is a different matter. Cable drive is only going to get harder as the years go by. I used to be able to get them made up in Omaha, no more, Colorado, Texas and Michigan are the closest places now. What exactly is the problem with the present yoke? Can it be repaired?
Everything I find so far says it is discontinued, so repair or used may be your only option.
this might help: J300P-10 (patsdriveline.com) Interestingly the catalog shows the speedo gear as integral on that model trans? Not seen that on other transmissions, they list one for mechanical and one for electronic. Learn something new every day!
I would still look it up in the Spicer catalog, often I find people have one sitting on the shelf, can't remember what it was ordered for and just want it gone. Sell it for used price for a brand new yoke. Once you have the yoke number you can search it both ways, by application and Yoke number. You'll need to know what series U joint you are using either way, the Spicer catalog will help with that, they list the dimensions.
Agree with the above. Spicer yoke catalog should get you the right yoke if you truly need a yoke.
I always went about it the long/cheap route. I bought a used truck and then outfitted to what I wanted, often with used parts. I would imagine that as long as the parts are still available that route would still be an option. IDK with air disks taking over how many spokes that can handle disk brakes, would be available? I know school bus chassies use them a lot, not sure on heavier trucks?
Positive or negative ground
Geoff Weeks replied to 61 Mack's topic in Electrical, Electronics and Lighting
I've heard that alot, but it has always been by non technical people. I haven't heard any conclusive proof. There are many reasons why I doubt the "corrosion" explanation. My Uncle was a corrosion specialist for USS and I wish I had thought to put the question to him when he was alive. 1) most corrosion is caused by air and moisture/salts external to the wiring, new sealed lights more or less prove the point, now the corrosion is not at the light bulb but at the connection, again where air and moisture can attack it. 2) we still have as many connections with either polarity and while the direction of flow at each connection is reversed you still have steel to copper, so if it would make a difference it would just move the corrosion point not eliminate it. 3) some point to galvanic protection of pipeline and bridge structures as proof, this misses the point that vehicles move through the air and to be effective you would have to charge the air around the vehicle to have any effect. 4) when positive ground was popular, little was known of galvanic corrosion or the effect or direction of electron flow in a dc circuit. With old simple vehicles, it just plain didn't matter, most gauges didn't care (later balanced coils gauges do) so it really didn't matter which way around the vehicle was. In the 6 volt era, you saw a lot of positive ground. When the switch to 12 volt as the common vehicle voltage is when we see negative ground become popular. It think it was more to differentiate from the 6 volt vehicles. Once semi-conductors started being used, it cemented negative ground. For some reason it is cheaper and easier to mfg semi conductors in that polarity. Old tube radios used vibrator coils to make a static inverter essentially isolating the radio power feed from the vehicle. I had an old Telafunken (sp?) out of a '55 Porsche that could be run on both 6 or 12 volt, positive or negative ground. Once transistor radios came in most were negative ground. An alternator requires diode in both polarities so no gain or loss there as to vehicle polarity. L/N an early maker of automotive alternators, went with "case neutral" construction so could be used on either polarity, most other mfg made the case one polarity or the other, requiring a different part number for + or - ground. With the abundance of semi-conductors in a modern vehicle, negative ground is almost taken over. You did ask Swishy. -
Front pinion seal
Geoff Weeks replied to Coulton's topic in Antique and Classic Mack Trucks General Discussion
Correction, I am wrong, it is not a U200 Timken, although it looks a lot like it. It is CRD117 Mack. I didn't know Mack made frontloading double reduction, all I know are the top loading. Bearing and seal kit: 205SP70 According to Weller for what that is worth. Quick search comes up with: PAI Online (paiindustries.com) -
Front pinion seal
Wow, old Timken axle. You might find a rope seal sandwiched in the front bolt on plate. I haven't pulled one apart, I'd have to look if I have any parts or service that cover that old "U" axle. -
New radiator and cooling system.
Geoff Weeks replied to RS Disposal's topic in Engine and Transmission
This type of system is called a "bottom fill" the expansion tank, whether on the top of the radiator or somewhere else is not open to the top tubes of the radiator or, in a cross flow (which is what I believe you have). The idea is the radiator stays full to the brim with coolant, while any air gets forced through the small vent lines to the expansion tank. When you fill the expansion tank, the coolant flows to the lower (waterpump inlet side) hose. as the block and radiator fill, the trapped air flows out the small vent lines to the expansion tank. With the engine running, a very small amount of coolant is forced (along with any air) through the small hoses to the expansion tank (sometimes referred as a "de-aeration tank), and the coolant, now free of air, flows back down the large hose and back to the waterpump. This means the radiator doesn't have to be the highest point in the system (expansion tank does) but does mean any points that could trap air need to be vented to the expansion/de-aeration tank. Often those points are the upper water rail near or at the thermostat and the upper or hot water out radiator hose. On a down flow radiator, often the upper hose/top tank vant can be internal if the de aeration tank is mounted on top of the radiator, just a small hole drilled thru will allow the air to bleed out. This prevents air from being recirculated when the 'stat is closed and hot-spots in the engine. -
Me too, plus Iike the ease of tire changes, only 5 or 6 nuts and inner or outer can be changed. One of my K's is on disk the other spoke, I don't think I'll change it out, but if someone really wanted disks and offered to swap spokes for disks, I likely would.
Funny that, spokes used to be the "fleet option" back in the day. Most all the fleet trucks and trailers ran spoke, Disk were the O/O option because they were shiny. Several of the companies I was leased to had spokes on their equipment up into the late 90's
several ways to make an educated guess. 1) if the engine has an alternator and not a generator look to see what polarity is grounded, Alternator care about polarity so should be marked. 2) if a generator the regulator may be marked as to polarity 3) if the truck has an ammeter and no alternator, disconnect any radios and electronics and hook up a battery and turn on as many lights as possible and see if the ammeter points to - or +. If negative, then you have the right polarity, if it points toward + you have it backwards. If the vehicle has an alternator, disconnect all wires before doing this test. 4) look at the terminal ends at the battery, larger terminal goes to +, the one with the smaller hole is - (this is for old post type batteries.) Since old trucks with generators and no radios they will not care and can be switched at will. -
I ran into a few that were NLA (trailer spec) and ABS has been around for a long time, I had a trailer with ABS and spokes. There are only a few different bearings/spindles in use today on drive axles. It only takes a little machining to accept a "tone ring" for ABS, so I would imagine all are machined to accept one even if it doesn't have one.
I still have it, I need to paint the frame, put the 5th wheel back on, de-identify and then sell.
I think as long as the hubs are available they could be special ordered. Right before I retired I saw a brand new side dump trailer being delivered somewhere with 24" rubber on it (hub pilot). It might not be a RPO but I would be surprised a mfg would say 'No" to a request for them. Might delay delivery for a while.
The baby moons were the only "Bling" on my trucks, the nut covers got a little grease on the inside to keep the rust off the studs. Getting hard to find 1 1/4" nut covers. The hubs in both pictures need a re-paint, but both were hard working trucks, not trailer/show queens.
Somewhere I have an exhaust tube adaptor, it is just right for installing speede sleeves on front axles. I had to paint it red so it didn't get used on some exhaust job.
Here: Metal Trailer Hubcap Mounting Bracket For 8 Inch Rear Hubcap On Trailer Axle - 4 State Trucks
BigMackTrucks.com
Our Vendors and Advertisers
