Looking at a 76 F Model that the owner says needs a clutch. This appears to be a 237 with a five speed. Any idea if this is a single or dual disk design? Push or Pull? Thanks-MBF
Is it just me or did those buffalo wings taste like chicken?
That year and engine, I'd bet on a 14" double disc pull type (dish type flywheel).
Before you decide that it needs a clutch, see if the pressure plate can be adjusted. Maybe someone unfamiliar with this setup tried adjusting it at the external linkage and had unsatisfactory results.
(Don't tell the seller that though, maybe you can get a steal of a deal on a truck that only needs a proper clutch adjustment).
