Guys, what are the names and amp ratings of the starter solenoid in the front drivers side of the truck and the 2 fuses/circuit boxes above that?
They are all corroded on my cabover and now I have no ignition/ignition accessories working.
Not sure where to start!
Ty
Sorry I thought someone would reply by now…. Your problem might be right there just pull everything loose and scrape everything. Nuts wire ends.Washers sometimes big issues are a very small. Fix Good luck.bob
The two things are called circuit breakers, and are available at most auto parts stores.   Also on Amazon.   Normal ratings are 10A, 20A, 30A and 40A.    Some come as 6v and some 12v.      You can get some other amp ratings but might be harder to find.  They are also called thermal circuit breakers as they reset when they cool down.    They can go bad.  Arching as they open up can eat away at the contacts.
Also, as said above, those corroded wires will cause an extra load on the circuit too.   Hopefully the corrosion doesn't go too far back into the wires, so that you can trim them shorter and add a new connector.  Although the one wire looks pretty short already.
