5 hours ago, Freightrain said:
The old boxes have that shuttle pump also.  I cleaned mine up in my Triplex.  There was an eccentric in the front bearing retainer.  It was fed oil from the cup cast in the passenger side of the main case, fed through a hole into input area and then down the main shaft to oil the gear bushings all the way into the compound.
My 107 has two PTOs mounted on it.  One is different then the other?
Should be one big one and one smaller one. And there was one that  attached to the back of one of the countershafts. I never used any of them but the smaller one myself. Biggest thing I powered was a Commercial Shearing C102 pump. A few mixers but they were off the front of the crank.
