2016 CXU613 ride height
Go to solution Solved by Joey Mack,
  • Solution
There is a hole in the frame on the left, between the drives. It is about 1 1/2" diameter. In the hole you will see a slot for a large screwdriver.  To adjust the height, you loosen the smaller bolt near the hole and then rotate the slot with a screwdriver.. this will move the control valve, which will raise or lower the frame.  Have you adjusted air ride on any other trucks before?
Ok thank I saw it. Let me play with it. This is my first truck.
