- 0
engine fan not engaging
Question
shilohwestphal
2004 Granite cv713 427 Problem is the fan clutch is not engaging. So under a load in a hard pull the temp gets high. The dash coolant temp gauge works correctly. Is there two temp sending units? if so, where are they located? So Im not real sure how to trouble shoot this. I have power going the the solenoid valve. But from what I have read, the ecm grounds the valve? So how do you check that? I also read that if the ac high pressure switch is unplugged, the fan should engage. I figured this out in the past while working on the ac. And the fan would cycle when unplugged. But now when the ac high pressure switch is unplugged, the fan does not engage.
Any help would be appreciated. Thanks
4 answers to this question
