  • 0
MP7
Mario R
Question
I have a MP7 and it has no power, no active codes and I see that the turbo pressure does not increase, I took the vgt out of the turbo to check the lever but it is ok.  There are no air leaks in the fuel system.
16 answers to this question
  • 0
well,, I fell like it may be a fuel delivery issue..  I would be curious what the fuel pressure is..  On a gauge, not a computer....  Do you have the tools to check fuel pressure?
  • 0
I was wanting to ask him the same thing...  PTT is cheap to buy,  the vocomm box is pricey, but I also dont know if there are other products out there.. this stuff moves faster than me now..
  • 0
I highly doubt he does. PTT and vocomm should come free with every truck purchase. You’re gonna need it….
  • Haha 1
  • 0
On 20/6/2023 at 16:37, Joey Mack said:
bueno, pensé que podría ser un problema de suministro de combustible... Me gustaría saber cuál es la presión del combustible... En un indicador, no en una computadora... ¿Tiene las herramientas para verificar la presión del combustible?
I was able to repair the truck, I said that it did not show turbo pressure but it did not have a check light.  The solution was to change the turbo pressure sensor since it had a lot of dirt that did not allow it to read and that is why it made the error in the turbo and lost power.
  • 0
Premium Tech Tool...  I suggest that you look to purchase it..  along with a Vocomm data link...  Glad it is fixed..
  • 0
1 hour ago, Joey Mack said:
Herramienta tecnológica premium... Le sugiero que busque comprarla... junto con un enlace de datos de Vocomm... Me alegro de que esté arreglado..
I have techtool
Answer this question...
