END673 in pan oil screen
Went to change the oil in my G-75. Decided to pull the bottom cover in the pan to clean the screen. Removed cover and found no screen. Looking into the removed cover I see the remains of 4 spot welds. Was the screen detachable or was it welded to the cover? Going to have to pull the pan as the tin cover or shroud at the bottom of the oil pump and pickup tube is cracked. Don't want it to completely fall free and potentially block off the flow to the pump.
