- 0
1988 RD690S Solenoid ?
Question
Casper1988
I am having some electrical gremlins in my Mack. Volt meter is sporadic and also the Dynatard stops working at the same time. I have checked the fuse block, ignition switch, battery grounds, fuses, I changed the solenoid under the dash by the fuse panel and it solved my issue but the metal solenoid is getting pretty hot. Do they run hot or do I have resistance somewhere else. Could my Alternator be putting out to much?. I'm not all that competent on electrical. Thanks, any thoughts would be appreciated. Need to move wood during mud season but don't want to melt anything.
5 answers to this question
