Ingersoll/rand Air Starter
rustydog
Here we go again!!....would anybody be able to direct me where I might be able to get rebuilt starter, or parts. Or by chance anybody nearby have anything available???
Model B21RH 6
Thx, rustydog
Rustydog,
Try ASAP - Air Starters And Parts - they stock remanufactured IR air starters along with the following:
Low Priced/High Quality ASAP Replacement Parts Vanes <LI>Cylinders <LI>Rotors <LI>End Plates <LI>Drives <LI>Pinions
ASAP Repair and Tune-Up Kits <LI>All Make Air Starters <LI>Seals, Gaskets, Vanes, Bearings, O-Rings
Accessories
<LI>Mufflers <LI>Lubricators <LI>Solenoids <LI>Relay Valves <LI>Palm Valves
Just click on the ASAP part - there is a link to the website!
Joe
Edited by Joe Hupp
Model B21RH 6
Thx, rustydog
Hey Rustydog, i have an extra air starter but it is a Start Aire starter, i put the IR starter that i had on my truck, the starter does work it started the truck fine, but it does need a drive gear, both starters work on the 673 if you have or could find a starting gear(bendix assembly) from an IR starter it will work on the "Start Aire" starter,
Mike
