500 Gallon Tank Weight?
GavinBrigade
So is it a round tank?  67" dia x 113" long?  Using an online calculator that is about 1300# for 3/16" wall,  though that does not take into effect the end plates or baffles.  Adding a few hundred pounds would maybe get you in the ballpark.
https://www.industrialmetalsupply.com/Weight-Calculator
So using that calculator it is 400# each panel(1600# for all four sides).  The ends are 250# each.
So that makes it 2100# just for the tank.  Add a few baffles(say #200 each) and you are at 2500# for rough numbers.
