My gauges starting acting up a day or two ago. The seatbelt light comes on and the gauges drop out and them come back up and the buzzer goes off every time. It's driving me nuts to put it lightly.  I'll probably get into it tomorrow but was looking for a little guidance on what to look for or if the the whole cluster needs replacing. Thanks in advance!
https://www.bigmacktrucks.com/topic/58056-instrument-cluster/
Cluster fix-1.pdfFetching info...
Could be a simple deal of pulling the plugs cleaning with contact cleaner and a light coat of dielectric grease Also look for loose pins on cluster where plugs connect.  other wise look at the pdf
The pdf covers a known issue and it apparently goes up to 2006 or 07.
Edited by 41chevy
https://www.bigmacktrucks.com/topic/58056-instrument-cluster/#findComment-427438
  • 4 years later...
Expand
Do you have the complete pin assignment for the plug or dashboard
https://www.bigmacktrucks.com/topic/58056-instrument-cluster/#findComment-548589
