R model cab bushings
Thinking about trying to tackle the cab bushings on the R I drive if it's not too much of a chore.  Anyone done it recently that could offer some tips?  I wanna know how deep I'm getting in before I start the job.  Is it as simple as unbolting the rear bushings and popping the new ones in?  Or do the front mounts have to come apart at the same time?  I'm assuming the cab would have to be lifted a little bit in the rear since it's sagging so badly.
The truck is a 1978 R612ST and it has a bar across the frame that the two cab bushings are attached to.  I'd love to post pics, but this forum keeps giving me an error message when I do.
It's not bad but you will need a bottle jack to lift the rear of the cab to pull out the bushings. The bolt heads are in the cab and a helper to hold a wrench under the truck makes it easier. The cab will rotate on the front bushings enough you don't need to touch them but it would be a good idea to replace those also as they are not expensive.
Worn out rear cab bushing sure make that thing "knock" don't they?????
Edited by Rob
5 hours ago, Lmackattack said:
The rear cab bushings are easy to replace but to be honest I dont think it will do much to make it ride better. Cab air ride would be better if the truck is set up to convert over fairly easy.
I don't honestly expect it to, I'd just like the truck to look like the cab isn't sitting on top of the fuel tanks.
