I am looking at a dynamotor sheet which lists the engine as engine model # ET673-260 with a serial # of 4B7058.
What is this engine?  The sheet says 260 hp @ 2100 rpm.
The  dyno sheet is showing 188 horsepower at the rear wheels with 15 pound boost and exhaust temperature at 850 f.
Right, looking at the chart shows different pump, injectors, etc.  I don't have info on the turbo number but the ENDT673 runs 11-12 psi boost and the ET673 runs 15.9-17.6 psi according to factory specs.
