Air leak
felicello122
I have a 2000 rd, problem is when I pull the trolley, or hit the foot pedal I have air coming out of my service line which is normal if my red, yellow, and blue knobs are in.This happens with them out, when in everything works normal. When bobtailing is the issue, I changed all the valves in the dash thinking I had a bypass, so now I'm leaning towards a tractor protection valve, or maybe a treadle valve, slacks are working, brakes are new and I have no other leaks except when pushing the pedal or trolley with the knobs out. Anyone ever encounter this problem, I hate doing those foot valves?
Anytime I have had air coming out of the service line without a trailer hooked to it , its been the tractor protection valve. I am with you. I hate changing treadle valves ! So I always start with the easy ones first . TP valves are not very expensive and usually pretty easy to get to.
Keith
