Air dryer rebuild
Thanks to wise guidance I received from youse (central pa for "you all"), I ordered the rebuild kit for my AD-4...
After removal I gave it a bath (I HATE ENVIRONMENTALLY FRIENDLY CLEANERS!!! GIVE ME SOME PETROLEUM BASED SOLVENT!) Anyway, I digress...
post-6773-0-20110800-1415922761_thumb.jp
Once I got it apart it was not hard to figure out the issue...the check valve had its check missing! It was an orifice!
post-6773-0-36162200-1415922776_thumb.jppost-6773-0-26960200-1415922788_thumb.jp
The bracket was cracked at both mounts so I fixed that up...also used large doublers to prevent reoccurance!
post-6773-0-83575200-1415922804_thumb.jppost-6773-0-30679400-1415922819_thumb.jp
Everything back together and it works like a champ! My compressor actually shuts off until cut in pressure! The dryer was like this when I got the truck...it is a wonder I didnt wear the compressor out!
post-6773-0-62990600-1415922830_thumb.jp
Lesson here...if your compressor cycles constantly, and you replace the governer to no avail, it is most likely the check valve in the dryer draining the wet tank!!!
