Low rpm on em300l
Jellybean
 Share
Go to solution Solved by b61mack,
Can some one tell me why my 1988 em300L will only turn 1600 rpms. When I adjust the throttle stop it will shut the fuel completely down. The previous owner must have fixed it to only run about 58 mph. I think it needs to run about 1750 to run 65mph.
I think:
The "M" in EM6-300 stands for Maxidyne, which means they will pull from around 1000rpm for use with the straight 5speed tranny and the "L" indicates a low speed motor,.lower governed max rpm....witch to me seem like contradictions. What transmission and rears are currently equipped?
I also thought that older maxidynes were set with operating range from 1000-1800+ for the maxitorq transmissions....i have been wrong before
Somewhere here, if you search, there is a thread with alot of the older engine codes and their meanings.....
Someone who knows what they're talking about will be along to help shortly..... :)
  • Solution
A friend of mine that ran a Mack dealership told me how to turn the RPM up on a 88 R Model with the 1800 RPM Maxidyne with the 6 speed air shift 5.55 Mack rears. I don't know if it was the right way or not but it worked. now turns 2100 and downshifts at 1200-1300. there is a plug on the backside of the pump ( kinda hard to get to ) that you take out maybe 22 mm , have someone turn the engine over while you look in the hole and you will see a slot with a pin in the center, use a long flat screwdriver push it down and turn clockwise about 5-6 turns to start with then you have to turn the engine over and do the other side of the governor( 1/2 way around make sure you turn both sides the same amount ). I don't know if it is good on the 4 valve heads to be turning 2100 - 2300 or not, this was a farm semi and worked good. someone on here should be able to tell you the long term effects on a 4 valve head.
1600 is to low even for a maxidyne. Are you saying even with no load it will only turn 1600? Mine will rev up to 2100- no load but will pull to 1750 then start to cut back the power. You may have govener trouble if you all ready verified you're getting wide open throttle via the linkage.
 Share
