Roseanne Rosanadana-It's always something
hatcity
Heard a strange noise from the motor today. Open the hood and the A/C belt(yes it was hot here today) is jumping and missing. Shut the engine and take a look. Belt is missing teeth and starting to seperate. OK, cut it off and continue the day. Go to NAPA, get a new belt. PIA to replace as you have to remove fan, and main belt. Had it done in a few minutes. Start it up again and check that belts are lined up nice.
What the hell? water pump is wet, bottom only. Thought was that maybe belt had hit the fitting and lossened it a little. Tighten again, start. NOPE. weep hole is where it's coming from.
Replaced water pump about 2 years ago. PIA also with the pulleys off and on, remove fan and coolant.
Need to call MACK in the morning. Hopefully they have one with the pulleys on.
Machine shop up the street did it last time, $25 cash 15 minutes.
Looks like saturday is booked now. No fishing
Always somethin with a truck
Damn! i gotta agree with that! it ain't easy to change ANY belt on a CX!.......................................Mark
Couldn't believe the crap I went through changing the Fan belt (Horton Fan) on one of my CXU's with an MP8. Not so much of a side of the road job anymore....sheeeesh...
Well the water pump is done. Total of 5 hours including running for a while to get hot and look for leaks.
Machine shop swapped pulleys again, but cost me $40 CASH
My body is too old to be doing this. Where's that boy of mine?
