Park brake
Cruiseliner
we had same problem on truck, been a while but there is a double shuttle valve around the back of the cab in the frame, it has a shuttle valve in it that sticks. trace the supply line from the valve it should go to the double shuttle valve. I think it feeds air from two tanks and it get stuck on one side and can't get enought volume. If i remember right it is about 4" long, air line in each end and air line in the middle supplies air to the parking brake valve.
