ENF707A cam and main bearings
Can anybody tell me if the cam and main bearings in a 707A gas engine are the same as the END707? I can find listings for the diesels but no luck with the gassers. If not, does anybody have a lead on where to get a set of each? The crank is not ground so a stock set is in order if possible. Any help or ideas are welcome.
Thanks
Greg
I have the parts list for EY707 gasser of 1943.
There are Mack part numbers:
Bearing
Cam intermediate 59GB 123A
Cam front and rear 59GB 122A
Crank main rear
upper 64GB 1684A
lower 64GB 1693A
main center
upper 64GB 1666A
lower 64GB 1675A
main front
upper 64GB 1648A
lower 64GB 1639A
All these numbers relates to bearings of a standard size.
Can say at least ED Lanova and END673 has different bearings numbers.
Vlad
