What's the difference
You are probably looking at a later LJSWX with the exposed radiator,those do look similiar.The LT had a longer hood,set forward axle,and was built for west coast operations.A standard LJ had a much shorter hood,front axle was slightly set back,and it had a sheet metal radiator shell.
Hood length on LT is longer than the LJ Models.I think the LT'S had a larger engine selection also the LTL'S had an aluminum frame and other lightweight option that the LJ'S did not offer.Don't go to the bank with this info. as I am not 100% sure. Joe D.
