My company's new tire changing policy
Green Dash
Up until a month ago, If you hook a trailer with a flat/worn tire, you simply brought the trailer over the shop where the mechanic would stop what he was doing and get you up and running asap. This would typically take 15-20 minutes, add a few more if it were an inside tire. As a linehaul driver, I am not compensated for this time as I would be for a breakdown on the road. I didn't have a problem with this because at the end of the week, I feel I am well paid for what I do.
In light of a few recent losses of wheels at highway speeds, the company decided to take a pro-active approach to resolving the problem. While our incidents have not resulted in any injuries or propery damage, we've all seen the destruction a wayward set of duals can cause, many times resulting in fatalities.
The new procedure is this: when any trailer tire needs to be replaced (even if it's only an outside tire) both tires and the brake drum are to be removed and all areas around lug nuts where metal to metal contact is made are to be inspected and grinded clean. This process takes close to an hour.
I want to make it clear that I am 100% in agreement with our safety department that this is a serious problem and I am proud to work for a company that will go to this extent to prevent it from happening.
The very day after the meeting in which we were informed of the new procedure, I hooked a trailer that had 2 tires that had not been legal for at least a few weeks. Fortunately, they were next to each other because the replacement time would have been doubled as the entire process needs to be repeated for each side and axle.
There has now been a rash of incidents where driver's are hooking trailers with tires that would have the equipment placed out of service if found by DOT. I had another such incident this past week which resulted in my neglecting to raise the landing gear before pulling a trailer ( I discuss this further in the stupid people=stupid mistake thread).
My point: Don't allow youself to be angered to the point where you are distracted and more likely to make a possibly dangerous mistake just because you have a few co-workers that are just too fuckin' lazy to write up a repair and red-tag the equipment if neccessary.
This concludes my rant and I will now return to being the cute, cuddly, intelligent, and humorous friend, forum member, and nephew that all of of you have come to love, hate, admire and respect.
Good to hear from you Mr. Jim - glad you got over your rant okay - I will let someone else test just how cuddly you have become.
Heh, Heh, he said member
Jim, sounds like they need to have a mechanic on 2nd or 3rd shift to look the trailers over so you gentlemen can get the job done in a timely manner. I can see your frustration.
We have at least one mechanic on duty 24/5. The main issue is there are drivers that either won't look at tire treads or bother to write anything up. If a trailer isn't red-tagged it could come in from a peddle run and be sent out on a linehaul run within an hour or two. In the particular situation I was in, I would've have been okay with running it to the Cumberland, MD terminal and tagging it there, but it was being relayed to a Richmond, VA driver who I know would have to cross a scale on I-81 below Winchester. I use to go through there quite a bit and they will do a DOT at 3am. I just don't have it in me to screw another driver like that. The company has stepped up maintenance since the new CSA scoring system began and all they ask is that you do a proper inspection and take the steps make sure equipment is roadworthy be taking it out on the road. That's asking too much of some, I guess.
I read through the rant before posting but when I got to the end the only thought I had was mmmmm...member. I can only assume that I made my point with the rest of what I wrote.
As always, your point was well expressed and understood!
Heh, Heh, he said "mmmmmmmmm...member"
Jimbo
Gudday M8
Your problem iz an easy fix
Here on the udder side of the world
When they drop off a trailer after a days work
they write up a report ifn when needed so next time the trailer is called on to earna $
all is fixed
LOL
May B
cya
§wishy
Jimbo
Gudday M8
all is fixed
LOL
May B
cya
§wishy
It's as simple as that but for some, that's asking too much.
I have a video from our latest safety meeting. A driver told the Safety Director that writing up equipment is not his problem. This was the Safety Directors response:
