1993 CL713 Low Air Buzzer
I am having issues with the low air buzzer not working. The buzzer comes on when you first turn the key on but will not warn you of low air pressure. The low air light light comes on and works just fine. I'm thinking there is an issue with the circuit in the dash. Anyone have this problem? Thanks.
I just replaced the printed circuit board on the back of the dash cluster for the same reason because of a bad diode for the low air buzzer.
Clamp circuit was allowed to float.
  • 3 weeks later...
