U model
cgallamore
The easiest way is to simply be on the webpage you want the link from...click in the address bar, which highlights the address, then right click, select copy...
In your post, just put the cursor where you eant the ling to be, and right click again and select paste...like so
http://www.bigmacktr...4864#entry94864
And viola!
Would rather had the U Model Service truck than the 1 ton GMC & 1 Ton Ford Service trucks i had in the family excavating business. 1st thing id done was put a 2 stick 6 spd or air shift 6spd or 7spd in it for the on/off road use . like having that extra low gear for soft ground . ;)
:mack1:
