Help Rob!
41chevy
After exhausting all the local suppliers and a few no so local ones , I come to the master for advise. :notworthy: :notworthy: :notworthy: :notworthy: :notworthy:
I need 16 AWG Female high temp flag connectors. They need to be the steel 900 degree sustained heat connectors not trhe copper alloy 650 degree ones. Figured it would be relatively easy to find since they are used in lighting, ovens and other high temp applications. But noooooo! Any ideas?
Try mouser electronics, www.mouser.com first. They have a bunch of oddball stuff. I'll get you a few more vendors tomorrow when I'm at work but that one probably has what you need.
Thank you!! Mouser carries Molex who makes the connectors I need. Perfect. Now I can get my heat treat oven on line again to do preheat for welding. Thank you, Paul
Glad that worked for you. I use them a lot for harnesses and such. Their catalog is about as thick as a dictionary.
