14.5" lowboy tires vs. 15":
Will the smaller tires mounted on open center rims fit the larger rim's bolt circle? These are NOT mobile home tires and rims but rather a semi trailer lowboy, actually a tandem tag trailer. It is an insurance total but the tires are very low mileage.
17.5 rims(tubeless version of 15") will fit on 15" hubs,but I doubt 14.5 will.
Hi Mike, when I run the existing tires out, (8.25XR15) I'll swap to the tubeless 17.5's. I've not measured anything yet as the trailer is in Springfield but if they'll fit, I may be able to get them cheap enough to run out also.
